Vacuum raising
Vacuum raising
I want to know that why do we Start the CW pumps(circulating water system)if we are going to raise the vauum in the condenser?.How the cooling is helpfull during condenser vacuum raising?
As same as in the Desalination plant we spray the water in the effects and as wel as we start the vacuum raising even the main steam is not admitted in the first effect of multi evaporated films type units. My two basic question are as under.
Why we spray the water even there is no Heat?
What is the advantage of water spray or cooling with vacuum raising?
Ahsan
Ahsan
RE: Vacuum raising
RE: Vacuum raising
