"Etch a Sketch files" in DWGeditor
I work for a Japanese company and I often receive CAD files in DXF format from Japan. When anyone at my company tries to open the files with AutoCad Lt 2004 they get the following error:
A shell command was not executed properly. Please confirm that all command line parameters and valid and try again (1).
Since I had SW2006 on my computer I was always able to open the files with DWG editor. But since I've load SW2007 this is no longer the cases. Why and/or what does the error mean?
Why is my handle 65Roses?
Please visit http://www.cff.org/aboutCFFoundation/About65Roses/ to learn why!
RE: "Etch a Sketch files" in DWGeditor
Are you getting the error with ACAD Lt or DWG Editor??
Did you load DWG Editor with 07?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Can you open the DXFs in SW07?
cheers
Got the error with ACAD LT 2004 and SW2007 DWG editor. Did not get the error previously with SW2006 DWG editor.
... but can you open the DXF files directly into SolidWorks 2007? .... not the DWGeditor.
cheers
File open, browse for DXF type file. Follow prompts.
Chris
AutoCAD 06
What are the steps you are doing to open DXF from SolidWorks (not ACAD or DWG Editor).
Chris
AutoCAD 06
Can you open in eDrawings?
What program is being used to create the DXFs in Japan?
Have they recently upgraded whatever it is?
Can you create your own DXF with SW07 and open in or DWGeditor? (or vice versa)
Have you tried repairing or re-installing SW07?
cheers
