ASME Code Stamp Required for a Pressout Vessel?
If a vessel is not subject to 15PSI+ pressure during the processing of product inside but is by a platen and press exerting 60PSI+ on the product to discharge it through a discharge nozle at the bottom of the vessel, does the vessel need to have an ASME code stamp?
Regarding the same scenario, the lid of the vessel is obviously removeable to allow the press to discharge the product. Does the lid need to be ASME code stamped also due to the fact that someone years later may assume that the ASME code stamp on the vessel also applies to the lid?
RE: ASME Code Stamp Required for a Pressout Vessel?
jt
Mike4
If you pop the tank and it was NOT codestamped and protected by an ASME VIII relief device, you're gonna' have some 'splainin' to do. If it IS codestamped, and protected, and you still expreience a catastrophic failure, chances are you won't go to jail.
Please start a new thread. Second, please hire some professional help regarding your pressure vessel design before someone gets hurt.
