HYSYS pipeline backdoor monikers
Anybody know of a complete list of backdoor variable moniker names for the pipeline unit in HYSYS?
I searched ther knowledge base and my comments to one of their proposed solutions seems to have initiated some action - but so far not list smile
So if somebody has compiled a list that the would like to share then i would be happy (im currently mostly trying to find the moniker for heat trasfer data: ambient medium=water, water velocity so if yu know that noe it will also do smile )
Best regards
Morten
RE: HYSYS pipeline backdoor monikers
What I have tried with mixed success is to copy the value of interest, and then paste as link in Excel. If you look at the formula in Excel, you can derive the moniker. Another approach is to record a script and examine the resulting text (script) file.
Here is a blurb from the code that I use, based on some example from the Hysys KB:
CODE
                'For the pipe segment Internal diameter data is stored at the following Moniker
                '   :SmallLength.550.#
                'Where # is an integer starting from 0 and refers to the segment
                'number within the pipe segment operation
                'If the segment refered to isn't set up yet then the empty value -32767 is returned
                'Other relevant Monikers:
                'Outside Dia-       :SmallLength.551.#
                'Elevation Change-  :Length.550.#
                'Length-            :Length.551.#
                'Num Increments-    :Index.551.#
                Set hyBDvar = hyBD.BackDoorVariable(":PressureDrop.500").Variable
                DisplayBdVar hyBDvar
                Set hyBDvar = hyBD.BackDoorVariable(":HeatFlow.501.0").Variable
                Set hyBDvar = hyBD.BackDoorVariable(":HeatFlow.531").Variable
                Set hyBDvar = hyBD.BackDoorVariable(":Temperature.500").Variable
                Set hyBDvar = hyBD.BackDoorVariable(":HeatTranCoeff.500").Variable
                Set hyBDvar = hyBD.BackDoorVariable(":Selection.502").Variable
                wksOps.Cells(myRow, myCol).Value = hyBDvar.Description
                Select Case hyBDvar.Value
                Case 0
                    wksOps.Cells(myRow, myCol + 2).Value = "Petukov"
                Case 1
                    wksOps.Cells(myRow, myCol + 2).Value = "Dittus"
                Case 2
                    wksOps.Cells(myRow, myCol + 2).Value = "Sieder"
                Case 3
                    wksOps.Cells(myRow, myCol + 2).Value = "Profes"
                Case 4
                    wksOps.Cells(myRow, myCol + 2).Value = "HTFS"
                Case Else
                    wksOps.Cells(myRow, myCol + 2).Value = hyBDvar.GetValue("")
                End Select
                wksOps.Cells(myRow, myCol + 2).Interior.ColorIndex = ColorSpecified
                wksOps.Cells(myRow, myCol + 2).Font.ColorIndex = FontColorSpecified
                Set hyBDvar = hyBD.BackDoorVariable(":Selection.506").Variable
                Case hyEmpty
                    wksOps.Cells(myRow, myCol + 2).Value = "No Insulation"
                Case 0
                    wksOps.Cells(myRow, myCol + 2).Value = "User specified"
                Case 1
                    wksOps.Cells(myRow, myCol + 2).Value = "Evacuated Annulus"  '1
                Case 2
                    wksOps.Cells(myRow, myCol + 2).Value = "Urethane Foam"  '2
                Case 3
                    wksOps.Cells(myRow, myCol + 2).Value = "Glass block"    '3
                Case 4
                    wksOps.Cells(myRow, myCol + 2).Value = "Fiberglass block"    '4
                Case 5
                    wksOps.Cells(myRow, myCol + 2).Value = "Fiber blanket"  '5
                Case 6
                    wksOps.Cells(myRow, myCol + 2).Value = "Fiber blanket - Vap barrier"    '6
                Case 7
                    wksOps.Cells(myRow, myCol + 2).Value = "Plastic block"  '7
                Case 8
                    wksOps.Cells(myRow, myCol + 2).Value = "Asphalt"    '8
                Case 9
                    wksOps.Cells(myRow, myCol + 2).Value = "Concrete"   '9
                Case 10
                    wksOps.Cells(myRow, myCol + 2).Value = "Concrete Insulated"    '10
                Case 11
                    wksOps.Cells(myRow, myCol + 2).Value = "Neoprene"   '11
                Case 12
                    wksOps.Cells(myRow, myCol + 2).Value = "PVC Foam"   '12
                Case 13
                    wksOps.Cells(myRow, myCol + 2).Value = "PVC block"  '13
                Case 14
                    wksOps.Cells(myRow, myCol + 2).Value = "Polystyrene foam"   '14
                Case Else
                End Select
                Set hyBDvar = hyBD.BackDoorVariable(":ThermCond.500").Variable
                Set hyBDvar = hyBD.BackDoorVariable(":Length.508").Variable
                Set hyBDvar = hyBD.BackDoorVariable(":Selection.505").Variable
                Case 0
                    wksOps.Cells(myRow, myCol + 2).Value = "Air"
                Case 1
                    wksOps.Cells(myRow, myCol + 2).Value = "Water"
                Case 2
                    wksOps.Cells(myRow, myCol + 2).Value = "Sand"
                Case Else
                End Select
                Set hyBDvar = hyBD.BackDoorVariable(":Selection.508").Variable
                Case hyEmpty
                    wksOps.Cells(myRow, myCol + 2).Value = "None"
                Case 0
                    wksOps.Cells(myRow, myCol + 2).Value = "User Specified"
                Case 1
                    wksOps.Cells(myRow, myCol + 2).Value = "Dry Peat"
                Case 2
                    wksOps.Cells(myRow, myCol + 2).Value = "Wet Peat"
                Case 3
                    wksOps.Cells(myRow, myCol + 2).Value = "Icy Peat"
                Case 4
                    wksOps.Cells(myRow, myCol + 2).Value = "Dry Sand"
                Case 5
                    wksOps.Cells(myRow, myCol + 2).Value = "Moist Sand"
                Case 6
                    wksOps.Cells(myRow, myCol + 2).Value = "Wet Sand"
                Case 7
                    wksOps.Cells(myRow, myCol + 2).Value = "Dry Clay"
                Case 8
                    wksOps.Cells(myRow, myCol + 2).Value = "Moist Clay"
                Case 9
                    wksOps.Cells(myRow, myCol + 2).Value = "Wet Clay"
                Case 10
                    wksOps.Cells(myRow, myCol + 2).Value = "Frozen Clay"
                Case 11
                    wksOps.Cells(myRow, myCol + 2).Value = "Gravel"
                Case 12
                    wksOps.Cells(myRow, myCol + 2).Value = "Sandy Gravel"
                Case 13
                    wksOps.Cells(myRow, myCol + 2).Value = "Limestone"
                Case 14
                    wksOps.Cells(myRow, myCol + 2).Value = "Sandstone"
                Case 15
                    wksOps.Cells(myRow, myCol + 2).Value = "Ice"
                Case 16
                    wksOps.Cells(myRow, myCol + 2).Value = "Cold Ice"
                Case 17
                    wksOps.Cells(myRow, myCol + 2).Value = "Loose Snow"
                Case 18
                    wksOps.Cells(myRow, myCol + 2).Value = "Hard Snow"
                Case Else
                End Select
                Set hyBDvar = hyBD.BackDoorVariable(":ThermCond.501").Variable
                Set hyBDvar = hyBD.BackDoorVariable(":Length.510").Variable
                'First get an array carrying the types of segment/fittings
                FittingTypes = hyBD.BackDoorVariable("FittingType.500.[]:Name.0").Variable.Values
                For j = 0 To UBound(FittingTypes)
                    wksOps.Cells(myRow, myCol).Value = j + 1
                    wksOps.Cells(myRow, myCol + 1).Value = FittingTypes(j)
                    'Do common stuff = Inner Dia only
                    Set hyBDvar = hyBD.BackDoorVariable(":SmallLength.550." & CStr(j)).Variable
                    If FittingTypes(j) = "Pipe" Then
                        'Do all the pipe specific stuff
                        'Outer Dia - may sometimes be empty call a procedure to deal with this
                        Set hyBDvar = hyBD.BackDoorVariable(":SmallLength.551." & CStr(j)).Variable
                        'Length
                        Set hyBDvar = hyBD.BackDoorVariable(":Length.551." & CStr(j)).Variable
                        'Elevation Change
                        Set hyBDvar = hyBD.BackDoorVariable(":Length.550." & CStr(j)).Variable
                        'Num Increments
                        Set hyBDvar = hyBD.BackDoorVariable(":Index.551." & CStr(j)).Variable
                        'Roughness - the monikers used to access this changed for Hysys 2.4 (build 3868)
                        Set hyBDvar = hyBD.BackDoorVariable(":Length.552." & CStr(j)).Variable
                    Else
                        'Do fitting specific stuff - K factor
                        'This moniker did not change for 2.4 so still need to open and close the view
                        hyBD.SendBackDoorMessage (":ViewSegment 1 " & CStr(j))
                        Set hyBDvar = hyBD.BackDoorVariable(":ExtraData.503").Variable
                        Set hyBDvar = hyBD.BackDoorVariable(":ExtraData.507").Variable
                        hyBD.SendBackDoorMessage (":CloseView")
                        ':ExtraData.503 moniker retrieves the VH factor
                        ':ExtraData.507 corresponds to the FT factor
                    End If
                Next j
Sorry for the undocumented stuff, but I suppose it'll give you some handle on how to proceed.
Cheers,
Joerd
Really great.
Thanks for the tips about using the script recorder!
Best regards
Morten
