Watering Control System?
Ok heres what im lookin for. I have built a hydroponics system for growing vegitables. I am now trying to figure out how to automate the watering system and would like to know what kind of valve I could place inline to turn the flow on and off that would be low voltage and I could use a rescued low voltage lighting timer to run? I am sure this can be done, but I really am not sure whether this is even an actuator or a valve. Any Ideas? Eventually this is intended to be a robotic self operating system.
RE: Watering Control System?
The next choice it to make one using some sort of timer and a solenoid valve, like a washer fill valve. More work and probably not that much cheaper unless you have some of the parts laying around.
Also, if you use 120v house current make sure you use a ground fault interrupter (GFCI). You see these in most bathrooms and kitchens, they have the little buttons. They are designed to disconnect the power in the event of a short circuit - which is what happens when you get electricuted :)
But another idea would be to use a pump on a timer. If you had a reservoir with a nutrient solution. Pump above veges and let it gravity flow through your distribution lines.
