dimension in crosshatch
Since upgrading to 2007 every time I place a dimension in a crosshatched area it no longer breaks the crosshatch and makes the dimension visible. Is there a setting to get this back?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: dimension in crosshatch
Tools > Options > Document Properties > Detailing and checkmark Show halo around annotations in the Area Hatch Display section.
Having a drawing open will activates all the pertinent options.
Was you SW07-SP0 install from the DVD/CDs, or from a download?
As handleman said, broken (and some other 'special') views can affect other features.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Logical thought would be; if the "halo" works in a regular cross-section, that it should work in a broken cross-section. But if the SW code does not allow this, how would anyone know? ... unless it specifically states in the Help files that it should work.
Most of the time if it worked in a previous version, then it should work in the latest... so you as a user can tell if it worked in a previous version better, because you all do what you do on a regular basis and we as Technical support have to do it all every day of the week.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
New users would naturally think of the OP's problem as a bug.
From a VAR's point of view, would it confuse the issue if the problem was reported as a bug to a VAR, and also submitted as an ER to SW?
