acid washing alkylate, clay
We use sulfuric acid to wash alkylate. I need to ensure that all the spent acid is removed. A settler is employed, as well as a collesor. Can I use a clay bed to remove the last bit of acid? What clay would be most suitable? Should ay particular form/shape/size of clay particle be used?
Thank you
