part cutout question
I have a model like a tennis racket with the handle standing up.
In the round section i would like to make a 5 cm  cutout slot  in the middle, going all the way trough the material.
The only problem, the slot must be tilted 17 degree from horizontal & and the center of this slot must be 2 cm off center (lower)
pleas help me
gr Anthony
RE: part cutout question
Anthony,
a picture indicating where to apply the cutout would be
helpful
dy
How do i post/add a picture?
gr Anthony
goto http://www.mooload.com  and follow the instructions
on how to upload. You'll get two pics from it one large
and one small choose the large one please. BTW: all
files you upload there are visible to the world!
dy
Anthony,
much better winky smile
I hope I got the picture. The file is zipped and V16. It
might not be the best solution but it does work ...
Tilted_Cutout
dy
dy,
The picture is basicly what i need to make, the problem i have,is how to put the slot in 17 degrees while keeping the pivot point on the same vertical centerline as the centerline of the main body, and the horizontal centerline  a little lower !!!
The drawing on the picture is just a example, the real measurements may be different!!
Anthony
Anthony,
that's the way the part is constructed. The slot is
50mm wide, its midpoint is 20mm below the center of the
base, and it's tilted 17 deg. against the base' face.
I've found one more solution so I've updated the file, same
location then before (holds both samples)
dy
Dy,
i can't open the file
file was created in different locale ........
gr Anthony
Anthony,
this does not prevent the opening of the file ther is a
button to open 'as specified' or similar labeled. I often
get these type of files
dy
Dy,
I have tried all sorts of opening ( opes as / read only / etc/etc ) but no succes !!
If no other way is possible, can you explain in text what steps i have to make.
First i make my basic model (no cutouts)
I think that after clicking the cutout button, i have to select parallel plane(for setting the lower center hight)Than select Angled plane (to set 17 degrees angle),am i going the correct way ? or completely wrong ?
gr Anthony
Altnickee,
If I may…
In Solid Edge Part.
Draw base feature.  Draw your tennis racket.
Create sketch (sketch1) on face of base feature.  Draw a horizontal line from the center or pivot point of your obround.  Don’t draw the obround yet.
Create new sketch (sketch2) on right (yz) plane or the side view if you will.  Draw a line connected from the pivot point  on sketch1 and at your 17 degrees.  Doesn’t matter how long the lines are.
Create new plane.  Create a normal to curve plane.  Select the line on sketch2, the angled line.  Now you have the base plane to draw your obround cutout shape.
Cutout.  Draw cutout obround shape on the normal to curve plane with the obround centered on the intersection between lines on sketch1 and sketch2.
Also see…
[URL=http://imageshack.us][IMG]http://img276.imageshack.us/img276/5182/tennisanyone1ee2.jpg[/IMG][/URL]
[URL=http://imageshack.us][IMG]http://img271.imageshack.us/img271/3616/tennisanyone2ok1.jpg[/IMG][/URL]
[URL=http://imageshack.us][IMG]http://img285.imageshack.us/img285/7012/tennisanyone3lj4.jpg[/IMG][/URL]
Hope this helps,
Jef
Jef,
The cutout in your example has a angle in the Y direction also, my cutout only needs a angle ( 90-17 degrees = 73 degrees )measured from the " handles" vertical centerline
 Anthony
Anthony,
which happens to be just that winky smile
@jef,
also a workable solution, good job. It can be improved
by making it more 'change resitance' (mine too).
BTW: as I see from the pictures that you are able to
read V19, true or false?
dy
Dy,
V19 ? i dont know , it seems that the pictures from Jef are made in Solid Works or pro enginering, solid edge dont uses the arrows as in the pictures.
I am still trying to make the cutout with no luck !!
As i am from the Netherlands, some technical words i dont understand, like " obround " ? So please have some patience,if i dont understand everything!!
gr Anthony
Anthony,
V19 does use the Triads (you named them arrows).
'Obround' or 'oblong' is that shape your cutout looks like
There is a function for that; you will find it as a flyout
on the Offset button when in sketch mode (Symmetric Offset)
Jef's pics should give you enough infomation to complete
your work I think, at the mo I've no clue where you got stuck
dy
Anthony,
/Edit
Dutch? hmm, then this forum might IMHO be of more help: it's
Dutch:
NL-Forum
The site seems to be down at the mo, you have to register
to post
dy
dy,
V19 yes.  So far no problems.  Loaded fine, runs fine.
jef
Hi all,
the Dutch forum is down at the moment, true. The company hosting the forum is moving right now. The forum should be up today again.
Greets, IJsbrand.
Jef,
so then you could get and read the file
Cutout
I've done it using your approach just to see how to get it more
robust/stable when one has to change it.
dy
dy,
I've already unzipped and viewed your file before I gave my first post.  I didn't have any problems reading.  In my model I was going for simple to reduce the typing needed.  No dimensions or variables used at all.
PS
In another thread I would be interested in discussing design and modeling procedure with any members.  I would like to see how my assembly modeling method stacks up with others using SE.
Jef
altnickee,
After looking at the pictures of your model you posted I think all you want to do is move the slot down 2cm?  If this is true then you need to move the profile used to make the cutout down 2cm.
With your model.  Right click over the slot cutout, edit profile.  Select all elements that compose the slot.  Select move button.  Click base point and type 0 in 'x' box and 2 in 'y' box.  Click down from original position to accept the move.  If you wan't to make the slot position more adjustable you will have to add dimensions as well.
I fear that I have over complicated the original question.
Jef.
Jef,
I know how to make a normal cutout slot in a disk shaped part (using the cutout button)
In a disk shaped part with a protrusion on the side, like a tennis racket form, standing with the handle up,i can make a normal cutout slot in a angle of 90 degree measured from the handle!!
My problem starts when i want to make a slot, witch is
90-17 degrees = 73 measured from the handle!!
And the center (pivitpoint) of this slot needs to be on the vertical line (the longest line)and 1 mm below the center of the disk !!
i am using version V16
gr Anthony
Hi Anthony,
Wy don't you make a "angled referenceplane" and use the cutout command on that plane?
Thanks Alwinus,
But nobody over here seems to understand what i am asking
Its a simple cutout in one plane .
If you draw a tennis racked shaped part (4mm thick) with the handle pointing up
On the flat side of this part,you have a horizontal centerline and a vertical centerline in this part
Than i want a slotted cutout (14mm long 3mm wide )witch horizontal centerlines are 17 degrees compared to the horizontal centerline in the "tennis racked shaped" part
The middle (pivit)point of this cutout needs to be at the same vertical centerline as the tennis racked shaped part,only 1 mm lower than the original horizontal centerline
I hope someone can give me good step by step instuctions
24 reply's given but no answers that can help me
 I am using Version V16 and cannot open /read later ones !!
Thanks to you all for the support sofar!!
Anthony
Alwinus,
Yes i see , but how ? please step by step instruction, so i can see where i go wrong !!
The picture of the cutout is it made in solid edge ? because
in  solid edge V16 i dont have the same picture!!
I always start in part, click the protrusion button,select a plane,create the part,than start to make the cutout.
Anthony
Anthony,
maybe this one too is of some help:
Sketch
BTW: have you ever done all the tutorials that come with
SolidEdge? But only if you don't mind ...
dy
I see that you are dutch and solid forum is down so here you go:
In V16 kan je deze cutout makkelijk maken, je moet alleen een "constructionline" gebruiken.
Deze lijn is een hulplijn die je 1 mm onder je hartpunt  en 17 graden schuin kunt zetten.(zie de gestippelde lijn)
Hierna kan je je eigenlijke cutout daar aan "vasthangen"
De hulplijn wordt niet mee ge"cutout"
Awin
Awin,
IK kom er niet uit !!
Ik heb eerst de instructies van donyoung geprobeerd
ook uit jou uitleg kom ik niet uit!!
Ben ik nu zo domme klootzak ?
Ik mag Solid Edge  gebruiken van en vriend (buitenland )
Heb mezelf er mee leren werken ( wel de solid edge  tutorials gedaan)
graag een stap voor stap uitleg
gr Anthony
Hoi Anthony,
waar zit je in Nederland? Belangrijkste vraag is: wil je dat gat wel loodrecht op het platte vlak hebben, of zit daar een hoek in?
Als je hem er loodrecht op wilt hebben:
pak de schets van FWC erbij.
1- teken min of meer je profiel (twee rechte lijnen en halve cirkels).
2- Zorg dat je lijnen niet op horizontaal geconstrained zijn.
3- Maak de lijnen parallel en de cirkels even groot met constraints.
Aan je tekeningen te zien was je al zover. Nu komt het:
4- Om het jezelf makkelijk te maken trek je je hele profiel even naar de plek waar hij ongeveer moet komen.
5- Geef de juiste maten aan.
6- Trek een lijn van het middelpunt van de ene cirkel naar het middelpunt van de andere.
7- In je menu's links zie je een icoontje met een doorgetrokken lijn en een gestreepte lijn, hiermee kun je van de net gemaakt lijn een constructielijn maken, dit betekent dat hij niet als profiel gebruikt zal worden, maar je hem verder voor alles kunt gebruiken.
8- Zet een maat van het middelpunt van je contructielijn naar het hart van je cirkel, zorg dat de optie van bematen op horizontal/vertical staat.
9- Het icoontje met een kruis kun je gebruiken om het middelpunt van je constructielijn recht onder het hart van de grote cirkel te zetten.
10- Nu alleen de hoek nog: Als je cirkel op het midden van het kruis van de vlakken staat is het makkelijk, je kunt het horizontale vlak gebruiken om de constructielijn de juiste hoek te geven, anders moet je nog een constructielijn maken van het rechteruiteinde van de cirkel naar het linkeruiteinde...
Sorry dat ik er geen plaatjes bij kan doen, bedrijfspolicy...
Succes, IJsbrand
"Alwinus,
Anthony"
Did you say you use "protusion" button to make a cutout? -Make sure to use "Cutout" button (2 buttons below) to make the cutout, or else the feature will fail! -Hope this may help you winky smile
IJsbrand,
Bedankt voor de uitgebreide uitleg!!(Ik zit in Amsterdam)
punt 1 (twee rechte lijnen en halve cirkels)Aan de text te zien begin jij in sketch ? zou het kunnen zijn dat omdat ik niet in sketch mijn onderdeel heb gemaakt dat het daarom niet lukt?
Ik ben begonnen in part/ protrusion/select plane/maak een cirkel (25mm)/twee vertikale en een horizontale lijn (als een dakje er bovenop )/met trim button onnodige lijnen weghalen zodat ik een gesloten figuur krijg/finish button klikken/dikte figuur aangeven/finish/part klaar
Nu druk ik cutout button/select plane
Wat ik nu zie ziet er uit als de schets van FWC
Ben ik soms verkeerd begonnen? had ik in sketch moeten beginnen ?
 punt 3 Maak de lijnen parallel en de cirkels even groot met constraints.? constraints? die functie ken ik niet,waar vind ik dat ?
 punt 4 Om het jezelf makkelijk te maken trek je je hele profiel even naar de plek waar hij ongeveer moet komen.Hoe bedoel je dit ? zoals ik ben begonnen staat hij al waar hij moet komen !!
  punt 6 Trek een lijn van het middelpunt van de ene cirkel naar het   middelpunt van de andere. Ook uit deze text vermoed ik dat jij in sketch zit te werken en ik niet ?
punt 7 OK
punt 8  Zet een maat van het middelpunt van je contructielijn naar het hart van je cirkel, zorg dat de optie van bematen op horizontal/vertical staat.
Optie bemating heb ik goed staan,Dat middelpunt vind je zoals in punt 9 ?
Als ik dit doe dan krijg ik of een foutmelding of de hele constructielijn komt horizontaal te liggen !!
punt 10 is duidelijk maar zover kom ik helemaal nog niet !!
Worden jullie al helemaal doodziek van mijn gevraag en geklungel ?
gr Anthony
Man kan jo også skrive en hel masse på dansk, som ingen kan forstå, det er vel derfor der ingen liv er på de hollandske CAD forummer, if you write english, someone else may learn a few tricks, we have no clue whatsoever and it makes it harder to help you... winky smile
Anthony,
I just saw the Dutch forum is up and running again, I will post the answer to these questions there.
Sorry English guys, It was just a lot easier to help Anthony in Dutch. Thank you all.
ps. Anthony, Ik vraag de beheerder of hij het onderwerp wil verplaatsen naar 'algemeen Solid Edge' Hier krijg je meer reactie over gebruiksvragen.
Greets, IJsbrand
when looking at the part's picture Anthony supplied then
you'll see that all is there. So the problem boils down to:
 - move the slot down
 - rotate the slot so that it will encompass an angle of 17
   with the horizontal plane
If one can't cope with this ...
dy
Thanks to you all for helping me with the making of my cutout !!!!!!
I want to mention one person by name for assisting me in a way that couldn't be any better !!
My special thanks goes to  IJsbrand Schipperus for his valuable help
A real Solid Edge expert .
Anthony
