Magnetic attraction between conductor and I-beam
How does one calculate the attractive force between a conductor carrying a DC current and some nearby steel?  We have a bus bar carrying 25000 amps next to a steel I-beam and need to figure out how much bracing we need to put between the two.
Thanks in advance for any help.
RE: Magnetic attraction between conductor and I-beam
There's no simple equation.  One usually resorts to finite element modeling in a situation like that.
Equation 6.3 here gives the force between a conductor and a steel plate.  This could serve as an upper  bound for the forcew between a conductor and an I-beam at same distance
http://www.consult-g2.com/course/chapter6/chapter.html
