QDIM Ordinate Justification
When I create a set of ordinate dimensions using the QDIM command, all of the dimension text is justified left. I would like to change the justification to right. I can't seem to find a place to change this.
What I am looking for is to have all end points of the extension lines straight across.
Any help would be appreciated.
JEM
JEM
RE: QDIM Ordinate Justification
Is there a way to move the dimtext from one side of the dimension line to the other.
I understand you can move the text one way or the other and it will "jog" the leader line at an angle, but I would rather just move the text to the opposite side of the leader.
JEM
The over-under is accomplished by placing a text override such as \X<> in the Override Text property. You could then match properties or you could also set up a "PREFIX" in the dimstyle for the override text. A couple of suggestions.
"Everybody is ignorant, only on different subjects." — Will Rogers
http
Note how the 26 1/2 and the 28 1/2 dimensions are staggered out from the 0 and 2 dimensions.
