Cooling Coil Water Quality
Anyone ever heard of any minimum quality spec for water in a cooling coil?  I assume this is in regards to calcium, bacteria, etc.  If so, what is the standard way of communicating water quality requirements?  The application is a SS cooling coil inside a slurry tank.  Thanks.
Caravoy
RE: Cooling Coil Water Quality
Ask the cooling coil manufacturer.  They should know.
