Epoxy coating of reinforcing bars
I have a project where I need to cut a 7' x 7' hole in an existing slab which is reinforced with epoxy coated bars.
When the hole is filled back in I want to weld on extensions to the cut off bars and then coat the extension bars with an epoxy to make it compatible with the rest of the bars.
Has anyone out there done this sort of thing? Any advice on specifications or manufacturers of epoxy resins would be appreciated.
RE: Epoxy coating of reinforcing bars
CRSI has answers/recommendations
I have gone for mechanical couplers and specified that these be epoxy coated too after installation.
Thanks again
csd72
