Searching 3D Content Central
Is there a search function that I can use to search 3D Content Central.  I'm looking at the user library, electrical, connectors and there are over 400 models.  Is there a way to do a keyword search rather than paging thru all the models?
Timelord
RE: Searching 3D Content Central
Thanks smcadman.  I never would have thought of that.
Timelord
A little trick:
If you select 3DContentCentral from the Design Library on the right of SW, then select the "Search Icon" at the top, you can search within 3DCC.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Timelord and Flores,
Curious ...
Did my suggestion work for you?
Chris
AutoCAD 06
ctopher,
Works for me.  I must be blind not to have seen that icon before.  Thanks for the tip.
Timelord
You may not have seen that icon before because it's new in SW07.  Searching through SW works for me intermittently; sometimes it works, usually it crashes SW (not responding).
SW07 SP1.0
Flores
It is also located in SW 2006.  You just have to select the drop down menu and then select "Search 3D ContentCentral".
It cannot be new in '07 because it is there for me in '05
Timelord
