Exchange data with CATIA V5, Settings for Step, Could settings improve
I exchange data with CATIA V5 alot and can't afford a PTC catia v5 to PRoe, PRoe to CATIA v5 translator. I want to know if these setting are the best? Are there other setting that I can add to my config.pro to improve translation.
these are the setting for exporting STEP files
step_export_format   AP203IS
export_3d_force_default_naming    NO
intf3d_out_extend_surface     YES
intf3d_out_surface_deviation   0.0001
intf_out_as_bezier      NO
intf3d_out_force_surface_normals   NO
intf_out_max_bspl_degree    16
the reason I ask is this I translated a part out of Proe that had a rib (or a pin) on it. It had a .1mm flat then a .3mm fillet all around the .1mm flat. When I translated it into CATIA V5, the .1mm flat lost its exactness or diffinition of its boundaries. Instead of being rectangular the edges were wavey.
Anyway, are the config.pro setting above could it be improved or I have notice an "OPTIONS" in the dialogue window under the save as "STEP" menu. should I create special configuration files?
Thanks in Advance - texaspete
PS I exchange data with UG NX3. are there better STEP setting (config.pro) or I have notice an "OPTIONS" in the dialogue window, should I create special configuration files?
RE: Exchange data with CATIA V5, Settings for Step, Could settings improve
I also import and export to CATIA v5......I use STEP with better success than IGES.  Here is one more item you might want to add depends on complexity of your geometry
INTF3D_IN_CLOSE_OPEN_BOUNDARIES
yes—closes open trimming boundaries of imported surfaces by connecting the end-points of existing boundaries.
no—leaves boundaries untrimmed.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
http://www.prostep.org/en/services/bp/
Poke around and look at the systems combo
("Choose your system"?) page.
Geom checks?
Accuracy - if you aren't using abs acc
open your STEP export and look for
uncertainty_measure_with_unit and the
value specified.
"Wavy" is the result of Catia trying to "heal"?
CATIA has a "direct" translator called Multi-CAX (PDL) that supposedly converts between Proe and CATIA.
Anybody tried it?  Comments?
