SW2006 custom sheet format
I'm putting together a custom sheet format for my company.  I've got the title block layed out the way i want, but some of the lines and all of the text are in a grayed out color - not black.  Everything is on the same layer, which is a solid black line.  Any clues as to what is going on?  Is there some other way to change the color of text and lines?
RE: SW2006 custom sheet format
You need to go to Tools>Options>System Options>Colors and in the system color box scroll down and select inactive entities and choose your color.
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
The gray color means it is constrained.  Turn on your Line Format toolbar.  Right-click > edit sheet format.  Pick your lines then on the Line Color tool, uncheck Default then pick your color.   I do this because I may not have all of my lines constrained on my border/title block.
SW07 SP1.0
Flores
Try toggling the Color Display Mode in the Line Format toolbar.
cheers
smcadman, you got it.  the line color tool worked.  thanks.
