ELIMINATION OF VAPOURS FROM THE SLOP STORAGE TANKS
In refinery I work with, storage space for slop and API separator are placed close to flare system. Slop tanks are equipped with fixed roof and breathing valve. API separator for gravitational separation of oil from water is an open system. Vapours and gases from this system develop freely into the atmosphere and pollute the environment.
Is discharge of gases and vapours from the storage space to the flare system for burning a good idea? If not, what is the best sollution to this problem?
RE: ELIMINATION OF VAPOURS FROM THE SLOP STORAGE TANKS
The API separator should be covered in any case. You should not be getting a large volume of vapors off the API separator if it is covered. Note that the API separator is frequently considered to be a fire hazard as well (another reason for covering it).
The extent of the air pollution control procedures is often dicatated by the local air pollution regulations.
Milton Beychok
(Visit me at www.air-dispersion.com)
Thanx for answers. However, I am still in the dark regarding second part of my original message. Please try to help again.
I'd investigate a few solutions. The first being dedicated thermal oxidizers, second vapour recovery systems, or a combination of those.
Thank you very much for your answer. Can you, however, be more specific about dedicated thermal oxidizers, especially if you have first-hand experience or know alot about them. If you are familiar with working example(s) of this solution in practice, better still!
Its a small flare that has supplimental fuel to assure complete oxidation of the VOC's
Covering the separator will drastically reduce the volume of vapors coming off. The cover may even eliminate the need to collect the vapors.
Then, you will have to evaluate the cost of a piping and a fan to force the vapors to the flare.
It is very doubtful that you enough vapors to justify installing an air pollution control device like dcasto recommends.
