Lost the QuickPick in Solid Edge Assembly
QuickPick still works in Part, Sheetmetal, Weldment, but not in Assembly. Makes it hard to insert new parts into an assembly when this function is not working. Any Ideas.
Still using version 12 running on Windows XP.
Brad
RE: Lost the QuickPick in Solid Edge Assembly
I have seen this problem regularly on V12, until they changed to a different QuickPick technology, at V14 I think. Make sure you have the latest (last) service pack for V12 as well as the latest driver for your graphic card. V14 at the time did solve the problem. Did you search for threads on "quickpick", I'm sure it's been discussed before the problem was well known. Good Luck! : )
Actually it's at V15 that they changed the Quick pick for the version that still stand today with the name of the parts instand of numbers.
Good luck
Patrick
