Frame Angle
Frame Angle
Frame Angle
Within in the framing function I can't figure out how to flip an angle. I know how to relocate its origin point of which it revolves around, but I need it mirror so the leg will point opposite of the current direction.
Currently itis oriented like this...
1111
1
1
but I want it oriented like this...
1111
   1
   1
I would have attached picture, but I could figure out how if the that is possible.
RE: Frame Angle
Check this FAQ on how to show an image,
FAQ559-1100
regards
RE: Frame Angle
I believe if you select the cross section with the nodes displayed, 'n' will cyle through the rotations...
RE: Frame Angle
once you rotated the angle, I think it's simply a case of selecting the node you wish to be centered on the path route...
