AWS Weld Symbology - Number of Fillet Welds
I have been reviewing the AWS weld symbols trying to understand how I call out a certain number of fillet welds on a drawing. From what I can see the number indicator (placed below the symbol) only applies to projection and spot welds. For fillet welds, I need to specify the length and the pitch between the weld centres. How do I specify how many welds I need in that joint (i.e. 3 stitch welds vs 4)?
Jeff
Jeff
RE: AWS Weld Symbology - Number of Fillet Welds
http://www.tech.volvo.se/standard/docs/56055.pdf
See.pg.11,12
http://engstandards.lanl.gov/
Look,around.
One the drawing show the total distance of the intermittent welding plus spacing to the start of the continuous weld.
For a 5x 2-5 the total distance is 28"
Opposites sides of the joint:
On the drawing show the total length of the intermittent welding.
For a 5x 2-5 the total distance is 22"
http://
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Jeff
Hg
Eng-Tips policies: FAQ731-376
