Standard Parts Library.
I'm trying to create some basic parts to add into an assembly.
Is the standard parts libary as bad as i think? or am i not using it propperly?
All i want is a hex or star button head machine screw
Is that too much to ask for?
if so, Is there another reliable source to find such items?
Thanks.
RE: Standard Parts Library.
which SE version are you running: V18 Foundation or Classic?
The Classic (bundled that is) has the Machinery Library which
AFAIK contains such items. The Foundation comes with that
limited free content only.
dy
Says classic.
licenced.. etc.
Have you installed all categories? It takes a lot of time to intstall all, so people sometimes opt to install only most used categories...
IJsbrand
I didn't do the install, our tech guy did.
I ll have to get the cd's and see if i can add that.
