API 650 Foundation Design Moment
BearcatEngineer (Structural)
Appendix E provides an equation to calculation the "overturning moment due to seismic forces applied to the bottom of the shell" as the follows
M=ZI(C1WsXs+C1WrHt+C1W1X1+C2W2X2)
My question is when determining what the bearing under the ringwall should be, should the I in Mc/I be that of the entire shell bottom(1/4*pi*r^4), or only I of the ringwall itself ((1/4*pi*(rout^4-rin^4)? Obviously you get two greatly different answers. I typically run my analysis until I obtain the required ringwall width. Just looking for some guidance, have been in debate for a while as to which way is correct.
RE: API 650 Foundation Design Moment
