how to know the current m-file directory in the mfile
I want to open a file with the path like this [current m-file dir]\file\filename.txt.  I found i cannot do like just textread('file\filename.txt'..) in the m-file. so i think i should know the m-file directory itselt first, then do the job. do anyone know how to do this? thank you!
RE: how to know the current m-file directory in the mfile
pwd, I think
Cheers
Greg Locock
no, when pwd used in m-file, it still returns the current work directory of matlab, not the m-file directory itself.
i got an ugly way,
s = mfilename;
s = which(s);
then delete the mfile name in the string s.....
o.O
Use / instead of \
try something like
cd('c:/path')
textread('filename')
This what you needed?
BsK
no. I need to know the current running m-file path dynamically to keep the m-file function has better adaptability when moving the m-file.
Another approach, which appears to be more gruesome, is to use depdir on the current file.  Unfortunately, it takes a while, since it crunches through the entire path and the last entry is the current directory of the m-file.
TTFN
