PVC Pressure pipe underground installation
Anyone have AWWA M23 or some other source that would give what the minimum allowable radius that PVC watermain pipe can be installed without fittings that is with joint deflection only. I'm drawing up a subdivision with curvilineal streets - hence the question.
Thanks for any info
gwbar
Thanks for any info
gwbar
RE: PVC Pressure pipe underground installation
