Plotting From 2007
Plotting From 2007
Since I upgraded to swx07, I have not been able to achieve the same draft quality. Even now when I plot from swx06 everything looks fine. But when I plot from swx07, the lines are very light and hard to read.
Is there a setting I have missed?
RE: Plotting From 2007
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I have noticed that when I go to the "page-setup" and select "black & white" it does not stay. Because the next time I check the page-setup it is back to "automatic". Is there a setting somewhere else that will make the setting stay on "black & white" in the page-setup?
Thanks for your help.
Set the "Page Setup" how you want it, run the print, then save the document to capture the print settings.
- use this document settings
- set each document... (checked)
When I set the page-setup to black & white, the print doesnt come out dark. The next time I check, it is set back to "automatic". Even when I check the settings again before printing, it reverts back to "automatic".
Pete
Thanks.
