Indirect Fired Heater Design
Hi All!
I'm just trying to verify the actual capacity of a indirect fired heater API 12K type. API 12K only gives a general guidance based on "standard capacities" from 100M to 1.5 MM btu/h
After following a laboriuos method to find heat transfer coefficients at the fire tube side, and calculate heat transfer for a specific service I found that I don't know what are the main restrictions in the hyraulic design of the fire tube, for instance flue gas speed through it in order to mantain a natural draft of air, or something else. Please I need some advice on that restrictions.
Thanks in advance
PD I've read
thread794-24190 where some British standard where mentioned.
Thanks in advance
PD I've read
RE: Indirect Fired Heater Design
Also you need to calculate minimum draught for the stack to get stoichiometric + 10 extra air through the stack.
You get a good reference on Kern's book on heat transfer but wife stacked it away in the loft years ago.
Ummm, would you have her dig it out and then sell it to me?
First you must know the Inlet Temperature, Pressure, and flow rates of Gas, Oil, and Water. Note the water is more critical.
Second you must know the coil split, like 4 passes upstream and 6 passes downstream.
Third you must know the desired outlet pressure and you can usually assume 70F for the temperature.
From this you can calculate the JT effect and thus know the capacity of the Indirect Heater. Also keep in mind, after the media leaves the choke you want this temperature to be +5 Deg above the hydrate formation line at pressure.
Most of the time you can just figure 35 to 40 Degrees F.
I got tired of doing this manual and wrote a spreadsheet program to make these calculations. Takes about 5 minutes, lol.
Allen
Sindel & Associates
www.consulting.awsindel.org
