Design Table / Excel Conflict
Has anyone else experienced SW locking up when trying to access a DT when Excel is running in the background? For some reason, when I exit a DT, the Excel process does not always shut down. The next time I access a DT, things work just fine until I attempt to exit the DT, then SW hangs, not allowing me to continue operations. I have to shut down SW using the Task Mgr and restart SW.
This behavior is consistent from the time we installed SW 2006 (we are currently on SW 2006, SP 4.1) across some 70 workstations, over 5 independant sites. My VAR can't reproduce the problem and tells me that there is apperently some software conflict...gee, thanks that helps!
M.B. Price CSWP
www.assembly-testww.com
Automated Assembly & Test Systems
RE: Design Table / Excel Conflict
Hope this helps,
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2006 SP 4.1
Dell 380 XP Pro SP 2
nVida Quadro FX 3450/4000
Thanks MacDuff!
M.B. Price CSWP
Which version and patch level of Office or Excel are you using?
SW07-SP3.1
SW06-SP5.1
I found that this works sometimes.
Colin Fitzpatrick
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
I am preventing the hangs by using the Task Manager to delete an EXCEL.EXE process every time I exit a design table. Idiot SolidWorks leaves this process running every time!
Still, the program continues to do other things like refuse to recognize a linked dimension name.
For a lot of the parts I am working on, the design table feature with configurations is invaluable. I just wish it wasn't such a buggy nightmare to work with.
Oh well, the extra HOURS I spend dealing with this nonsense at the front end is more than made up when it comes time to produce the 2D drawings.
Are you having any other problems with functions not working?
Have you tried a clean uninstall/reinstall (with AV off)?
SW07-SP3.1
SW06-SP5.1
I was told it was not enough memory, so they got me a new computer. Still happened...just quicker.
Once we upgraded to 2007, I have not had the problem once.
If you get this error often, it might be worth the upgrade.
