IR Transmissivity of Nylon
I would like to detect teeth on a sprocket made of nylon 6 using an IR opto-interrupter. The sprocket is 0.110" thick. The LED emits IR at 940 nm. Will the sprocket teeth successfully block the IR? Where can I find the IR transmissivity of Nylon?
RE: IR Transmissivity of Nylon
These links from BASF regarding laser welding of thermoplastics might help.
http:/
http:/
Harold
SW2007 SP1.0 OW2006 SP4.0
www.lumenflow.com
This is helpful - thanks!
