Reynolds Number
Reynolds Number
Reynolds Number
                          I am wondering how you calculate the Reynolds Number, Re, for wire moving in a fluid. What
                          characteristic dimension do you use; and what criteria do you use to determine a turbulent state?
                                My approach would be to use
                           Re = vD/viscosity(k)
                           v = velocity of wire D = diameter of wire
                           viscosity(k) = kinematic viscosity
                          And to use the criteria for flow over a flat plate. Does this make any sense?
                          Thank You
                          Don
                          dleffingwell@snet.net
RE: Reynolds Number
what kind of values do you get?  do they make sense?
