Applying for PE License in Multiple States
I am licensed in one state and need to be licensed in anoter state. It's not automatic and requires resubmitting most of the information originally submitted for the first license.
Has anyone used the NCEES record program where a record (experience, references,etc) is established that can be used when applying for multiple licenses?
RE: Applying for PE License in Multiple States
You can check on NCEES website as to which state accepts which part of the NCEES records.
There is a $25 annual charge for renewal of the record. They will transmit all data to the boards you request at extra charge. NCESS records and references becomes very handy when records get older than 5 years or if you have a few employment changes.
The key benefit comes in verification of old references, that if NCEES has done it, most states would accept it.
I have heard of a service which provides all of the data for submittal, where someone actually sends in all of your data for you, but it is much more expensive.
