floor joist spacing
floor joist spacing
hello all,
I'm preparing plans for a 2 story + basement house and had a question on the floor joists for the first floor. I have specified 2x12 @ 24" OC SPF #2. the loading is 50psf LL + 10 psf DL. the joists work for l/360 deflection and are close on allowable stress. the house width is 28' with a center beam so the design span is slightly < 14'. the house is in NY. My question is will 24" spacing be ok for hardwood flooring, a local contractor recommended 16" spacing to make sure there is no problems with whatever flooring system the owner decides on using. thanks....
RE: floor joist spacing
I would stick with 16 inch spacing as stated by others.
Also, I would expect for 14 ft spans, 2x10's wouldat 16 would satisfy most performance requirements (especially if #1 S pine of D fir. #2 might also work. L/480 live load requirement is a common standard for good performance. Ther eis much written about this in some of the engineered wood joist producer's sites.
If you are supporting a tile or stone finish, agree with above posts that 16" is best, particularly if you don't know exactly what the finish is going to be yet.
then go to publications, then technical papers. Cheers
Another consideration beyond what is structural would be that extra room for ductwork if joists are spaced at 24".
Hope it helps.
Rarebug
