Is there a PIV that is flush with the ground?
I've rerouted an existing fire loop around a new building on a manufacturing plant site. The owner wants a PIV at every valve location. These are surrounded by 4 bollards. The 2 valves I need to make the connection to existing fire main are in very awkward locations to have an above ground PIV with 4 bollards around them. Is there such thing as a PIV that is flush with the ground? (It must also be FM approved)
RE: Is there a PIV that is flush with the ground?
Try to reroute your piping to accomodate your layout.
