HARDWARE EXCLUSION FROM BOM
Hi All
When I "exclude from BOM" all hardware thru their "properties" tabs, they change to their "default" sizes.
Ive done this many times before at other places with none of these results.
Makes for some very large screws. Using SW2005 sp5.0 with network located toolbox. Any ideas? Thanks
RE: HARDWARE EXCLUSION FROM BOM
Check the references and see if the files are being pulled from the server... but big bolts are a direct result of the configurations for those parts being lost... has nothing to do with Exclude from BOM.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Thanks SBaugh
References are correct. What would cause configuration loss?
Someone deleting them, replacing the TB parts with maybe their own DB that was located locally prior... and they didn't have the sam configs as what was once in there... a change in location and the wrong DB being transferred.
Those are some of the biggest reasons I can think of right at the moment.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I can go back and individually pick the correct size thru each component's properties. When not listed, I have to use the "replace" function. Thanks
