Switch statement with cell arrays
I want to use a switch statement with a cell array as the case expression. I know it can be used with few expressions like this:
switch lower(method)
case {'linear','bilinear'}
disp('Method is linear')
But I have a fairly lengthy switch statement where one case needs to look for numbers 4 through 100:
switch number
case {'4', '5', ...'99', '100'}.
disp('display something')
Does someone know how to make this work without writing out all 97 numbers?
Thanks for your help.
switch number
RE: Switch statement with cell arrays
if (i>=4) && (i=<100)
display('?')
else
break
Or somehting to that effect.
That do what you are looking for?
BsK
First, define and convert your cell array in one for loop before the switch. (convert to a string in order to be used in switch statement):
for n=3:100
num{n}=num2str{n};
end
Then, in the case statement you input the complete cell array:
case num %no curly braces or parens
statement;
otherwise
statement; ...
Works fine.
