Problems during results visualization
I'm working on a coupled pore fluid- stress consolidation but I have problems in the visualization of the results.
After I complete the job an error message appears during visualization:
Deformation and/or analytical surface extent is too large as compared with the model.
Could you suggest me a solution?
RE: Problems during results visualization
Use the display option and remove instances from the view that you think may be the problem.
corus
Probably this isn't the solution because I've only one istance  in my model. I've tried to change some options in the visualization step, but I couldn't find the right one to solve the problem.
Isn't there another way?
