Radial pressure drop
The case is to find a mathematically derived equation that describes the loss, when a flow goes from axial to radial direction. The pipe diameter is 8mm, the bore in radial direction is 4mm. Wall thickness is 5mm. How can I find the loss? Personally, I will consider this as an orifice to simplify the problem, is this a correct assumption?
