Readily available Mil-L-7808 near equivalents???
We have an epicyclic, splash lube gearbox application in a remote area of Mexico that requires periodic servicing. We qualified the unit using a MIL-L-7808 lube as it usually is available on the sites that use this device. Are there more readily available equivalents or near equivalents (auto trans fluid ?) that could be specified for use in lieu of the synthetic?
Thanks for any help.
RE: Readily available Mil-L-7808 near equivalents???
I would research the QPL-7808 for the manufactures that are qualified to manufacture MIL-L-7808.  They might sell this very same item under their own label for a lot less.  I just looked at the QPL their are a least a dozen manufactures listed with their trade names for the lube
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
One of the more common brands you will see is Anderol. Also this oil is sometimes used as a dielectric oil.
You should be able to get some oil meeting your spec at any airport.
Look down at the turbines and compressors.
http://www.anderol.com/pdf/Industrial%20Lubricants%20(Yellow)%20Brochure%20-%20Oct%2022,%202004%20-%20reduced%20file%20size.pdf
