Need help/suggestions on the basics.
Can anybody suggest some good books or manuals that can explain the basics of fluid dynamics. I have to admit that fluids was far from my favorit class in college. Now I have been out of college for 6 years and not used any fluids since school.
Currently I am working on projects that are HVAC related. When it comes to the thermodynamics I am no pro but I have a better grasp of things. However when it comes to air flow in ductwork I am a lost cause.
I know that there are ways to look at ducts or pipes and determine the loss coeficients for flow as well as for heat. I have see it done before but I have no idea how to do it.
I need a book that I can use to walk thru how to do htings like this. I deal mostly with air (Compressiable fluids) so I want to focus on that but I don't mind re-learning some about liquids or incompressiable fluids. I need something that is well written and easy to understand with good examples.
I need to get a grasp on this stuff as quickley as I can.
RE: Need help/suggestions on the basics.
Have you tried the "ASHRAE Fundamentals Handbook" ? Expensive but pretty much answers everything.
Bruce
Years ago (1981), I obtained SMACNA "HVAC DUCT SYSTEM DESIGN" which is informative for the beginner. I do not know if it is still available.
I need soemthing that is more simplistic and walks you thru topics and then thru example problems.
