Add excel BOM into drg template?
Does anyone know a way i can auto insert a excel based bom into a drawing?
I need to serup std drawing & BOM layouts.Im sure there is a macro way however my vb skill in none.
Also when creating a drawing with 2 sheets the open assembly is only linked to the active sheet, when you select the 2nd sheet none of the view are populated, is there also a way to do this?
Sorry if the questions are slightly confusing.
Cheers Lee
Cheers Lee
RE: Add excel BOM into drg template?
As for your other issue, there isn't anything iN SW I know of that will auto insert views into a second sheet after you add it... you ca drag and drop you model into the sheet and it will make a 3 views for you.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
