Equivalent Grounded Spring Element in Ansys?
Hi all,
I used to use grounded spring elements in Nastran to simulate elastic boundary conditions for a given structure. What would be the equivalent element to use in Ansys? If there isn't one, how do you normally model elastic boundary conditions in Ansys?
anne
anne
RE: Equivalent Grounded Spring Element in Ansys?
COMBIN14 should be what you need (spring/damper). You can't directly tell the program that it is "grounded", however it is sufficient to fully-restrain the destination node.
cheers
anne
