What if.. solar cells
Currently solar cells cost around $4 per peak watt. 1 peak watt of cell gives you around 7 Wh per day of electricity on a good day, or 4 Wh if it is poor weather.
There are several technologies coming up in the next five years that could see solar cells dropping to around $1 per watt. In fact even now the price is driven by high unsatisfied demand rather than production costs. My house uses 1500*24 Wh per day, so I'd need 9000 peak W of cells, which is almost viable at first sight, given that my current bill is around $800 pa.
So, how would your field be affected by cheaper solar power?
Can YOU think of a good diurnal storage technology that we haven't seen yet?
Cheers
Greg Locock
RE: What if.. solar cells
It's amazing how much poltical resistance wind turbines are getting. Neighbors don't want to see them. "Spoils the view." What a load of bull! Farms don't exist for the sake of generating bucolic views, they are working enterprises.
Seems to me that with the right cell efficiency that a solar powered car would be possible.
Really, wind power is just a form of solar as well... Wind has become pretty big in west Texas (where there are few people to complain about the view being spoiled.)
-The future's so bright I gotta wear shades!
In order to get acceptable performance you have to optimise everything, including weight. This leaves you in a large expensive fragile slow single seater.
Much better to put the cells on your roof, and then charge the battery for your electric car up.
Cheers
Greg Locock
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
As far as spoiling the beauty is concerned,its a treat to watch all the wind mills running. Next time I pass the area, I shall remember to take a few pictures and post it here.
"Solar cells and advanced fuel cells that can deliver up to 500 kW must be developed to power the craft. An aerodynamic design and a control system must be developed to help keep the airship steady amid the high winds at that altitude, without consuming excessive power. Another important factor is determining how the airship would react to changing temperatures as the sun rises and sets every day, heating and cooling the helium. Then there's the major challenge of finding materials for the airship's skin that are capable of withstanding the extreme ultraviolet radiation at such high altitudes for extended periods without becoming brittle."
To know more about this go to
http:/
MEGA GRID
A massive HVDC power bus through linking the midwest to
the east as far as OHIO.
The purpose of this bus is twofold. First to average out
the availability of power because of weather patterns.
The wind is allways blowing somewhere right??
Also to deliver surplus to the hungry coastal areas.
Spurs off this MEGA GRID to the north and south with insure
it covers a very large geographic surface area to aid with
the weather averaging.
It will be extremely costly to build. Maybe even cost as
much as the Iraq war, but it should begin planning now.
There is no viable storage technology at present except
pumped resevoir water power that can even come close to
doing this averaging of power production for us. Hence the
need to spread out and connect the generation.
The capacity of the main trunk line would have to be
50 Giga Watts. Something like two cables 3 feet thick at
1 mega volt. It will be an engineering feat to rival any
before. But it is necessary
What you say is true, although I have heard that we could start to see significant increases is silicon production by the end of '08.
But this only affects the single and poly crystal silicon solar cells, not thin film cells. In fact, the high price of silicon is really driving investment in thin film PV at the moment. Your guess is as good as mine as to whether that investment stays after silicon prices come down. But CIGS, in particular, have been getting a ton of investment in the last year. Look at Nanosolar in Palo Alto, they just built a 100 million dollar factory to produce CIGS cells.
The article states: "The tight polysilicon market could last two years longer than previously expected, possibly continuing to 2010 or 2011".
The article is available at www.eetimes.com, but you have to setup a login ID to view it.
Solar Power Made Affordable;
http://w
Thanks for the update. Any mention of the reason for the additional delay?
Anyways, that's good news for thin film PV.
A) IC grade wafers supplies are sufficient, but solar grade polysilicon has been in short supply for two years already, and demand is skyrocketing.
B) Projections had been that shortages would end in 2009 when polysilicon vendors such as Hemlock, MEMC, Mitsubishi Materilas, REC and Wacker added additional capacity, but the increasing demand is outstripping original projections.
C) Solar cell and module makers are having trouble keeping up with US demand.
OEMs are working at better power efficiencies while reducing panel costs. Some companies are developing thin-film arrays which use less polysilicon but are less efficient.
The article mentions Solarbuzz LLC, which I found at the website: www.solarbuzz.com
It's true that the current thin film cells aren't as efficient as the older silicon technologies but they also have a lot of advantages, one being material costs. And there are a lot of good ideas in the works for higher efficiency thin film cells. So I don't see the efficiency of silicon cells defeating thin film cells.
It will come down to production costs, and, frankly, the industry has been doing an abysmal job when it comes to the production side of things. I have seen some signs of change, but I'm not convinced yet.
Which oddly enough if you refer to my first post, is just what I need.
That and a load of batteries (or whatever).
Cheers
Greg Locock
I see the real problem with current solar cell technology to be their embodied energy. Are they finally generating ten times the energy in their lifetime that they take to make, transport to site and install? Then you can call solar a "green" technology- and not before. Windmills, on the other hand, don't suffer from this problem- because they deal with a concentrated form of the solar energy rather than depending on the solar flux directly.
Saw some articles recently about people trying to mimic biological photosynthesis as a means to generate/store solar energy, ie. using chemical photosensitizers. What they neglect to mention is sensitizer degradation. Unlike a tree, any device we build won't be able to make its own sensitizer to replace the amount that the sun de-activates, bleaches or otherwise destroys. The sun is tough on chromophores long-term. If the sensitizer costs more to replace than the energy you produce is worth, you don't have a process. Evolution has come up with a pretty good system- mind you, it had a couple hundred million years to do it.
http://news.bbc.co.uk/2/hi/in_pictures/6113552.stm
http://
The neighbours won't be bothered by noise pollution.
Birds are far less likely to fly into the blades ... except for Seagulls and Cormorants ... and that would be a good thing anyway.
Doesn't take away from useable property and gets away from the NIMBY element.
Maybe they could also double up with wave power.
I found this stuff that could be useful for you to solar energize your house
“A "typical home" in America can use either electricity or gas to provide heat -- heat for the house, the hot water, the clothes dryer and the stove/oven. If you were to power a house with solar electricity, you would certainly use gas appliances because solar electricity is so expensive. This means that what you would be powering with solar electricity are things like the refrigerator, the lights, the computer, the TV, stereo equipment, motors in things like furnace fans and the washer, etc. Let's say that all of those things average out to 600 watts on average. Over the course of 24 hours, you need 600 watts * 24 hours = 14,400 watt-hours per day.
From our calculations and assumptions above, we know that a solar panel can generate 70 milliwatts per square inch * 5 hours = 350 milliwatt hours per day. Therefore you need about 41,000 square inches of solar panel for the house. That's a solar panel that measures about 285 square feet (about 26 square meters). That would cost around $16,000 right now. Then, because the sun only shines part of the time, you would need to purchase a battery bank, an inverter, etc., and that often doubles the cost of the installation.
If you want to have a small room air conditioner in your bedroom, double everything.”
About your statement “solar powered car is never going to be practical” definitely you don’t like to be outrun by a snail.
That is already being done. Shell for instance has a large wind energy business and is siteing windfarms on off shore locations, including old platforms.
Don't count on off shore stopping Nimbys. Just ask Teddy Kennedy about the one planned off the north east coast of the US.
My initial thought would be that a few thousand wind turbines wouldn't take any more energy out of the wind than the millions of trees that used to cover much of the worlds land area.
That's not to say it shouldn't be investigated but while one turbine probably takes more energy than 1 tree I doubt there'll ever be as many turbines as there were trees.
Plus I live out in the Mojave Desert and have stood down wind from vast swathes of turbines in the Mojave/Tehachapie area and believe me if they've taken 75% of the energy out then Bakersfield on the far side of the turbines would have been flattened by hurricane force winds.
Having said that, I am a hypocrite on this. My house is ALL electric, and my hot water is warmed by off-peak electricity. Ultimately (in Australia) that means my hot water is coal-fired, inefficiently. That is, the coal is burnt in a very high efficiency boiler, turned into electricity fairly efficiently, transmitted to me, somewhat efficiently, and then used to heat water fairly efficiently. I have a strong suspiscion that this is inefficient compared with a domestic coal fired boiler. But at current prices, why wouldn't I do it this way?
Cheers
Greg Locock
The answer in the US to your question, "Why burn any hydrocarbon in a stationary installation?" is ... because that's what the environmental movement wants us to do.
Leading up to the 1970s, much of the electric power not produced by hyrdoelectric means was produced by burning coal, heating water, running a turbine to turn a generator. Nuclear power was on the rise but environmentalists were convinced we would either blow ourselves up or live in a world of background radiation cause we didn't know how to dispose of the spent fuel rods.
At the same time, they discovered acid rain, a low acidic impurity in the atmosphere due to carbon release at coal fired plants eventually causing the formation of carbonic acid, in very low concentrations.
The environmental movement was able to shut down the development of nuclear power technology and insist that all coal fired plants be converted to oil fired plants which burned cleaner.
I agree, we should wake up and recognize gasoline and deisel should be used for ground transportation. Grades of petroleum that can not be used for transportaiton fuel should be used for other well suited purposes and we whould generate our power without petroleum when we can. If all the government regulations were eliminated that interfered with the proper allocation of resources, I wonder what the market solution would be?
a grift to 2dye4
Continental SuperGrid
[image http://w
Cheers
Luis
There's a role for regulation and for taxation: the market doesn't price stuff properly, especially in situations where one person's consumption results in costs for others.
A close second would be neclear if we didn't have all the regulations, look at Europe.
Likewise, I believe there are limits in polution that need to be established. My problem is that there are severe government restrictions in some aspects of energy that do not apply to other areas. This is an area where politics severely interferes with the proper allocation of resources.
For my part, I am outraged that China polutes the way it does while the environmental movement makes little to no fuss over their behavior. Likewise, the European community that uses a large amount of nuclear power and permits their automobiles to generate much more polution than US automakers are permitted in this country, points the finger at the US as the principle player in global polution problems. Environmental outrage directed at the US is dishonest given these facts.
If we could play by European rules, we would have much more nuclear power, reducing polution and the strain on global petroleum assets. When I ask for governmental regulatiions to be lifted in order to permit the proper allocation of resources, I am speaking of the arbitrary rules that have shut down the nuclear power industry, and other capricious rules that permit poluting by some folks but restrict poluting by others. Level the playing field and let engineers figure out where the resources should be used.
Dave, do you have a figure on lumens/watt on LED- incandescent-florsecent lights? I'd like to know how those compare. They are using a lot of LED matrix signal lights in my area now. I like them because they are redundant. I suspect they are also efficient. I just don't know to what degree.
Oh, have you got figures for the pollution emitted by European and USAn automobiles? I am intrigued by your claim.
Also, what are the relative contributions to global pollution?
Cheers
Greg Locock
Dinosaur, I'm with Greg. I'd be interested to know on what basis you make your claim to see if I'm wrong.
Based on my limited experience I'd say the average mpg for vehicles in most of Europe is a lot higher than for the US. Less SUVs and a lot more small (sub compact) cars.
ht
I couldn’t find anything definite for comparative average mpg between the US & Europe but strongly suspect Europe is somewhat lower.
http://en.wikipedia.org/wiki/Fuel_efficiency
http:/
The second link does give allthough it doesn’t cite a reference It sounds a reasonable estimate.
Also on the nuclear power front, yes France uses a lot but I don't think the rest of Europe is particularly high and doubt the French tip the balance that far.
http://en.wikipedia.org/wiki/Nuclear_energy_policy
I suspect the % of European energy from nuclear is a little higher than the US but not by as much as you imply. Interestingly the US is the largest producer of Nuclear power though it is only around 20% of its total electrical consumption.
Boeing-Spectrolab with funding from the US Dept of Energy has created solar cells with 40.7% efficiency.
ht
This is why I have the opinion that European Cars don't meet our emmision standards ...
Imported motor vehicles are subject to safety standards under the Motor Vehicle Safety Act of 1966, revised under the Imported Vehicle Safety Compliance Act of 1988; to bumper standards under the Motor Vehicle Information and Cost Savings Act of 1972, which became effective in 1978; and to air pollution control standards under the Clean Air Act of 1968, as amended in 1977 and 1990. Most vehicles manufactured abroad that conform with U.S. safety, bumper, and emission standards are exported expressly for sale in the United States; therefore, it is unlikely that a vehicle obtained abroad meets all relevant standards. Be skeptical of claims by a foreign dealer or other seller that a vehicle meets these standards or can readily be brought into compliance. Nonconforming vehicles entering the United States must be brought into compliance, exported, or destroyed.
Note the emissions control standards. I have been told more than a few times that you can't just drive a European car in this country because it doesn't meet out emission control standards. Once you make it meet our standards, it is essentially a US car. We have been meeting this air quality standard since the late 1960s. That's why I say I want them to come up to our standards before they have anything to say about us.
For certain emmisions, as I stated in my post, the US has lower limits. However, the average european mpg is around double that of US vehicles. So for CO2 and water vapour I assume the average euro vehicle is correspondingly lower per mile. Obviously not everyone considers CO2 & water vapour pollutants but certainly reduced fuel use does have an impact on the environment.
Or you could just drive vehicles with European/Japanese levels of efficiency and reduce the strain on petroleum that way.
So you feel europeans should meet your emission standards for certain specific chemicals before they say anything about you, while europeans probably feel you should meet their levels of fuel efficiency before you impune them.
Comparing US and European cars on MPG is once again comparing apples to oranges. The US does not have the population density of Europe and that is the basis for many differences between US and European culture. My European friends living in the US are quite happy with most things american. My British friend, in particular, is more upset with the folks who don't notice the light has changed to green. He drives a bigger car than I do though.
Back on topic.
There are various proposals for photoelectric power stations. At the moment they are a pretty expensive option, something like 4 times as expensive per kWh as coal powered stations. But, if the price of cells drops, that suddenly looks like a good idea. Somebody has conned the Victrian government into subsidising a fairly large PV station.
Here's another one. The peak load on the electricity grid is typically on hot afternoons when everybody switches their A/C on. So, if cells dropped a fair bit in price, why not power A/C from local solar cells? When the sun is shining is when you need the AC. Peak load electricity is the most expensive, and is typically from gas turbines, so even though this is not a great way of using the cells (much better to install a proper domestic PV plant) it may be more cost effective.
Cheers
Greg Locock
