Drive Shaft Phasing Question
This is a motorcycle drive shaft. The output from the gear box has a sliding spline/rubber "doughnut" flex coupler; the opposite end of the drive shaft (input to the final drive) has a single cardan which is wedge pinned to the pinion gear of the final drive.
The flex coupler consists of a fixed "yoke" out of the gear box which mates to a rubber puck (doughnut) coupler, with another splined yoke (90 degree's to the first) on the aft side of the "doughnut". The forward tip of the drive shaft is splined and slides into the aft yoke. The horizontal alignment of the drive shaft between the output of the gear box and the input of the final drive is less than 5 degrees.
Can anyone tell me if this type of drive shaft arrangement must have "phasing" between the flex coupler and the U-joint at the final drive?
Bill G.
Bill G.
RE: Drive Shaft Phasing Question
