blue water
blue water
i have read all the comments on this question and still have no answer for me. i have a well. i have a culligan treatment system - sand filter, 3 graduated filters, uv, and softener. while a glass of water will not look blue, a bowl will. it is sky blue -not really greenish. neither potassium nor sodium softeners has made a difference. culligan has tested the water and found copper and ph within limits. what else can i do? i do not drink this water (but my dogs do). it seems to me that there has to be something wrong insider the house. otherwise, you would think that all the filters would have pulled out the color. any help greatly appreciated.
RE: blue water
Orenda
RE: blue water
RE: blue water
RE: blue water
If the water source is a municipal authority, they can provide the mean copper level of the incoming water. If this is about the same as the measured copper from your tap, then your piping is not the source. If you are using well water as the source, the same applies, though you'll need to have that analyzed.
Orenda
RE: blue water
RE: blue water
I had the exact same thing. You fill up a glass, and it is not evident. However, as you fill larger items (5 gal bucket, bathtub, etc) there is a distinct blue to the water. I had our water company rep (city system) come out to check the water. She argued with me that it was not blue, and since it was not blue in a glass, then it must not be anywhere. We showed her the tub, and she claimed it was reflections from something in the bathroom. However, there was nothing blue in the room. I then took a 5 gallon bucket outside and filled it. She agreed that there was a blue tint, but it was nothing they were concerned about or would do anything about.
We then went and had it tested for copper among other things. Nothing was present in any significant levels. To this day, I am still unsure of what causes the blue tint, but I don't have a rash of neighbors dying off from bad water
RE: blue water
There was a thread on another posting discussing the color of water.
The attached photograph shows a pond left of center with an aqua blue color. The color is due to a high concentration of calcium sulfate in water.
If you will provide a complete analysis of your well water, someone can probably identify the material causing the color.
h
RE: blue water
If you are worried about the house why don't you take a sample near the well. The first thing I checked for concerns with my well was the neighbors. The new copper limits make it a little more worrisome, but it is also important that some of the standards are based on consumption for a very long time. I might also check right before your filter system. It sounds intense.
RE: blue water
RE: blue water
RE: blue water
I have always enjoyed working with well drillers, especially when they spend an hour with willow cuttings to site the well.
RE: blue water
As others have stated such applications/sources might well not have anything to do with your "tint", but I just thought I’d add I think at least some such salts etc. are indeed “blue”!
RE: blue water
http:/
As far as well dowsers go, stay away from them. Any competent well driller would have nothing to do with such quackery.
