Steel columns in aggressive environments
Dear all,
Could one of you help me to solve the following problem?
There are some steel columns (existing) sitting in a high acidic environment. Acids can attack the bottom part of the column that might lead to severe corrosion. I do not want to encase the column with concrete as fixing condition can change.
What is the best way to protect these steel columns?
Clefcon
Clefcon
RE: Steel columns in aggressive environments
For protection of structural steel column bases we normally used a Coal Tar Epoxy. One in particular was Bitumastic from Carboline. There are several manufacturers of these coatings.
http://www.carboline.com/product_brands.aspx
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
