Interpreting Plate Reaction Results
Hello. I'm using Risa 3D. I've modelled a large footing under a 5 story concrete stair tower that provides lateral resistance to EQ forces. I'm a bit green using RISA 3D (or other finite element software for that matter).
I've modelled the footing as Plates, 3 feet thick, and generated spring supports at the nodes. If my typical plate size is about 1 foot square, and the vertical node reaction at a node common to four plates is 0.3 kips, am I correct to interpret a soil bearing pressure of 300 pounds per square foot?
Thanks in advance to whoever is able to help!
RE: Interpreting Plate Reaction Results
