Relief Vent for Atm. Tank
Hey Guys,
We are looking at closing off manways on a process tank that we blow slurry into and pump out of. The tank is maxed out at a liquid level of 60% capacity. This tank does have a seperate 8" Vent. The tank drawings has no MAWP for it (just states ATM.) For open vent capacity correlations, there is always a differential pressure term, but there can't be one here since I don't have a MAWP. If a MAWP was 1 psi, then I would know I would need x capacity at 1 psi pressure drop to know that I am safe. How would I determine the capacity of the vent if I don't have a difference in pressure (MAWP of vessel assumed to be 0 psig)
Thanks.
Thanks.
RE: Relief Vent for Atm. Tank
Good luck,
Latexman
I'm a qualified relief device sizer and reviewer in my company who has attended Root Cause Investigations on devices I sized or reviewed, and I'd make the advice of a vessel engineer part of the permanent relief device record, but that's just me.
Good luck,
Latexman
So I believe your only option is to have a qualified vessel designer rate your tank for its pressure and vacuum handling capability and then you can complete your vent sizing. Probably not the answer you wanted to hear - it certainly wasn't for me either, but I know of no other.
Doug
