SOFTWARE - FATIGUE BEHAVIOUR and LIFE EXPECTANCY CALCULATIONS
Dear Sirs,
I am trying to find any software taking into consideration the Fatigue behaviour (and Life Expectancy Calculations) according to :
EN 12952-3 - (latest 12/2001 edition) Water-tube boilers and auxiliary installations - Part 3 - Design and calculation for pressure parts - Chapter 13 + Annexes
EN 12952-4 - (latest 02/2000 edition) Water-tube boilers and auxiliary installations - Part 4 - In-service boiler life expectancy calculations
If you know any development about the previous points :
a) Price including fees ;
b) Maintenance ;
c) Updates ;
--> Can you please explain how claims, further explanations, clarifications, updates are taken into consideration !
Sincerely,
A_Tsampalas
b) Maintenance ;
c) Updates ;
Sincerely,
A_Tsampalas
RE: SOFTWARE - FATIGUE BEHAVIOUR and LIFE EXPECTANCY CALCULATIONS
The referenced codes have provided equations that define the charted curves- it should be a simple matter to program these curves into an Excel spreadsheet.
You may want to try Google these fatigue codes together with excell or xls keywords.
<www.
This outfit made FE/Pipe and develop engineering software. They are about as knowledgeable as you can get on fatigue and life expectency of pressure vessels
