how to get from row,col to cell coordinate?
I've been the net for hours now before posting this questions. The question seems trival, but here we go:
How can I get from a selected or activated cell it's coordinates in the form <characters><number> e.g. "QA23" I does not seem to be in the properties of the Cell, I know one can convert the number 3 into the character 'C' but I was hoping excell as built-in support for it, but I can't seem to find it. thanks for your help.
Alwyn
Alwyn
RE: how to get from row,col to cell coordinate?
Excel.Activecell.Address
This will give you the cell in the form of $(column)$(row), or $QA$23, for example.
Is that what you are looking for?
=CELL("ADDRESS",qa23)
As an aside I find CELL("FILENAME",a1) to be very useful, also
CODE
Dim s As String
Dim arr As Variant
s = cell.AddressLocal(True, False)
arr = Split(s, "$")
GetColumnAlpha = arr(0)
End Function
The AddressLocal() leaves the SheetName! out of the result. The True and False parameters are for whether you want absolute column and row references (i.e., the dollar $ sign in the address). I leave the absolute reference for the row so I can use it as a split delimeter.
HTH,
Nick Hebb
