VBA sldw type library
Hi All,
I just uninstalled Soliworks 2005, completely cleaned the registry and directories. Then I installed Soliworks 2007.
Everything is fine until I wrote a small macro to test the VBA. Inside the VBA, the Ctrl+space and the browser work fine but I did not have the Auto Member list drop down after I type the .(dot).
I check the reference and here's the list by order:
1. Visual Basic For Applications.
2. Solidworks Extensibility Type Library.
3. OLE Automation.
4. SldWorks 2007 Type Library.
5. SolidWorks 2007 Constant Type Library.
6. SolidWorks 2007 Command Type Library.
They are all pointed to the right directories. I did move the priorities up and down but it did not help.
Also when I use MS-Excel VBA and add Solidworks Type Library in the reference, I could not see any response after the dot.
TIA.
3. OLE Automation.
TIA.
RE: VBA sldw type library
Maybe you need to check your VBA Editor Options.
On your first Option Tab must be something similar to 'List Elements' it should be checked ;o)
or you Declared your swApp as Object ?
cheers
Michael
Dim swApp As SldWorks.SldWorks
Dim swApp As SldWorks.SldWorks but it did not help.
Maybe I have to cleanup my hard drive. I have so many things in there like Visual Studio, Sun Java, Eclipse etc...
I'll keep on looking though because I need those software in the system for an on-going project.
