Precast concrete panels in saltwater
We have a lagoon with 700' of 9' high existing concrete bulkhead which is old and spalding in areas.Owner wants us to drill in dowels and attach 6"x6" wire and pour a new 8" face in front of old wall.To avoid pouring concrete in saltwater tides we want to use a 6" thick precast wall panel and anchor it to the face of the wall with a 1" spacer and then pour grout behind the precast panels to fill in the voids.Question is what would be the best anchor system to use between precast panels and concrete wall,panel will be 10'x 9' x 6".Secondly is this a viable solution to avoid casting inplace and what type of longevity would the precast give us?
RE: Precast concrete panels in saltwater
The cast-in-place concrete will easily take care of any of these problems and the anchoring will be more or less continuous (in case there are unexpected weaker spots in the existing wall). Also placing concrete in a tidal zone is not a problem for a Contractor who knows what he is doing. Suggest only inviting Contractors that you have prequalified to bid on the job.
www.SlideRuleEra.net
The inaccuracies of the past constuction could be taken care of by making your spacing away from the wall more.
Why not just leave a void behind the new precast? Design the new precast "facing" to span between anchor points.
Intrusion Prepakt
www.marineconcrete.com
