spacing to ground at 5kV
What is the spacing in inches from a 5kV cable lug to ground, in this case the cover of a j-box?
standaman
standaman
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: spacing to ground at 5kV
CSA 4160V is 2.5" P-G and 3.25" P-P...
However if your system is resistance grounded instead of solidily you should use the 3.25" for both P-P and P-G..
Any case if you can get P-P go for it..
TULUM
